I have a Harig 612 surface grinder that I've had but never used. The time has come that I need it. When I first got it i tore the entire thing down cleaned inspected adjusted. I've got it leveled using my 199 and the oil pump/flow dialed in. Today I decided I would make my first mess and what better way to learn than to grind the chuck. The chuck is way far out. Large hump In middle. I made the rookie mistake of taking to much off at 1 time and got some hot spots. Luckily chucks have some material to work with because I'm going to need it
I have a few stones and wheel dressers. Im unsure what the grit or make up each one is. I dont know what stone I should be using. Any pointers on how to go about this? I think I need to rig up a coolant system on this unit first and formost.
