Surface grinder... a tiny one.
Congratulations!
You mean SG-48 right? (not gs48 as written above)
There is some limited info here: http://vintagemachinery.org/pubs/detail.aspx?id=18132
That looks very useful for small jobs, I could see making custom rotary broach cutters on that.
-brino
:confused 3: Doh! Yeah that's exactly what I meant.
One of the first things I thought of was sharpening my collection of end mills I picked up a few years ago for dirt cheap. I have a KO Lee grinding fixture but it's way too big. Anybody have one of those import end mill grinding fixtures? The same as featured in ThisOldTony's video. If so, I would greatly appreciate a measurement from the base to the top of the barrel. Basically an overall height dimension.:congratulate:
Found it. For future readers, one website listed the base to top for the 5C collet version as 95mm. The ER32 collet fixture version is 85mm. Converted it's roughly over 3" for both. Google enough and you can usually find the answer.
I just found one a little smaller.... Weight is 300lbs
This part looks like the cross slide cover on my Logan. Does it have a part number that starts with LA?
