Hey All,
Should i be able to achieve a smooth to the touch finish with a 1942 South Bend 9? I'm using HSS tools. I started out turning a rusty piece of 2-inch A-36. All the rust is gone, and getting close to my final desired diameter 1.500. But no matter what I change (spindle speed, feed speed, depth of cut, tool end, oil), I cannot achieve that smooth finish. I still feel slight discrepancies when I run my finger across it. I've attached a photo, but I do not believe you can see much in it. My best finish comes from a high spindle speed (690), shallow cut (.002), round tool tip (~1/8"), with oil.
Is it my technique, the lathe, the material, or the phase of the moon? Let me know if there are any questions i can answer that may help in formulating an answer.
Thanks!
