The coupling came in for the conveyor drive. I had to bore it to size and install it. The shafts even lined up with no wobble.
Bought a couple of switches one for the conveyor and one for the main motor. Installed in the electrical box and finished up the wiring.
I had some 2 1/2" wide sandpaper 100 grit and glued the hook and loop material on the back.
After a few cut adjustments with the sizzors I wound the sandpaper on to the drum.
Now for the first real test I found a scrap piece of poplar that I had used to check the temperature of my branding iron. As you can see there were deep burn marks and an uneven surface.
This is how it turned out after taking about 0.100 off.
I expected there would be a few things to work out from the beginning but there weren't any. The only thing I adjusted was the conveyor speed as I had it too fast. The board was sanded to within 0.010 thickness all around with a very smooth surface no scratches or lines. The conveyor tracked perfectly and the belt never slipped. The wood didn't slip on the belt and the press rollers worked fine also. The sanding belt stayed smooth and tight on the drum with no indication of coming off.
Everything just worked like it should but oh what a mess, saw dust all over the shop. I guess I got really lucky.
Next will be some covers and a vacuum port for the dust.
Thanks for looking
Ray
