Super Simple Power Draw Bar for PM-728V-T
Tio Loco...I would buy one if you made another. I need one for my PM-728V-T. I was going to make one but why reinvent the wheel.
Thanks, but unfortunately I have to pass. I have an ever growing list of projects on my plate, and with the exception of the Drylin bearings, this one was built with materials that I had on hand, which I now no longer have on hand. Also, I didn't draw up any plans for this one (bad idea) and just made it on the fly.
If you decide to build one, I'll gladly share some basic dimensions.
This is the ratchet I pickedm mostly because the nose is relatively uniform diameter (just a slight taper): https://www.amazon.com/gp/product/B000MQEKTY
The 3D printer motion rods are here: https://www.amazon.com/Sunhokey-Hardened-Chrome-Metric-Tolerance/dp/B07XD4FBVM/
If I were doing it again I would just bore the the carriage block for the Drylin bearings and use external snap rings to secure them. That would eliminate the side wings, 20 holes drilled, and the alignment issues to get the pillow blocks properly aligned for smooth travel, but the pillow blocks are here: https://www.amazon.com/Furiga-Printer-Linear-Bearing-Bushing/dp/B08BZ48XZN
The Drylin bearings are here: https://www.amazon.com/gp/product/B076NWK2NK
For springs, you're on your own, like I said, they were RC truck shock springs, but they've been in the bin for years.
I had to ask :). I appreciate the response and the links. I'll give it a go when, like you, I have an opportunity.
Those ratchets will be shot very quickly turning with the spindle.
I've been using my CP butterfly ratchet for 5 years still going
