Having experimented with making a few rings, I thought I would respond. The main
problem with machining a ring is that when you cut the ring, it springs out and
is no longer round, more an elipse. If you build a jig that centers and holds the
ring holding it together with the desired ring gap, you can turn the outside surface with
a very light cut and the ring will seat all around the circumference in the bore.
The rings will not seat if you don't do this.
