- Mar 26, 2018
- 2,719
Without reading the whole thread, I see one major deficiency in this image. In each of the breakout boards, the GND pin is not connected back to the micro controller power ground. So the metal case of the USB socket isn't grounded, nor are your USB cables themselves. So any shielding on the cable is doing nothing.Thanks for everyone's suggestions so far - to answer one of the earlier questions, there is a fluorescent light about 15 feet away. The jumpers are about 6 inches long. I've included a photo - my suspicion is that my relatively long, unshielded jumpers with header pin connections are picking up / generating some sort of noise. In the photo you can see the ground wire I've attached to one of the mounting points - I don't think a ground loop is the issue, since the scales aren't currently connected to anything with a ground (they're resting on the tabletop for now).View attachment 356802
Ideally this GND would be tied to earth ground (third leg of your power adapter), but if that isn't possible, then it should be tied to the DC common as close to the source (DC barrel jack) as possible.
