- Apr 1, 2013
- 1,142
E350, You said earlier that light from the arc was getting in your hood from behind. What is it reflecting off of? Do you have the hood set so it comes down to your chest? I can tell you for sure you can get a nasty welding burn on your eye from a reflected arc. I got one once from a guy welding behind me. The UVL was being refected off my safety glasses. As far as having a hard time seeing that can be from having a bright light behind you when you weld. Like outside in the sun. I some times throw a towel over my head to block sun light.
Don't take chances with arc flash. If none of the things said seem to be the issue and you think it is the hood get it checked out. Anybody that welds can tell you if it is working right or not as long as they can weld with it. Think local fab or body shops. But a welding supply should also be able to help. But of all the advice you have got not using it until you know what is going on is the most important. (I know i'm not the first to mention it)
Mark: I have only had time to watch the first three videos. They were excellent. But don't you know its not "mechanized inert gas" welding (Or even a "metal inert gas" welding machine). Chuck previously corrected me when I referred to my other machine a "mig machine" it is a "wire feed" machine which is also capable of FCAW-S or FCAW-F. After that I thought well duh... I guess pretty much if you plug it into an electrical outlet, it is "arc" welding.
I think you got Chuck wrong on that. I think he was saying the machine is not a MIG machine it is a Wire feed machine (wire feeder) MIG is One of the process that it can perform. (GMAW) MIG is the same as calling GTAW TIG lot easier to say. Metal Inert Gas Welding, The video guy calls it Mechanized Inert Gas welding. that is where I was saying I lost intrest.
All the videos are good but the last one I posted (not the MIG one) seems to have the best example of what to look for in the puddle. it is at like 14: 20 or somewhere close to that there will be arrows pointing to things while the guy is welding.
Mark
Mark
