Put some oil in the spindle threads and replace Chuck.
Put in lowest not back geared speed
Rotate Chuck such that one jaw is horizontal and front.
Place biggest adjustable wrench you have on it to create a lever.
Old process was to use Chuck key.
Get biggest heavy helper like object and gently tap on said wrench.
It is the transfer of energy that will break it loose.
Heavier is better as you are gently tapping.
Small hammer no food as large mass of Chuck absorbs energy.
A 5 pounder not so much.
Sent from my SAMSUNG-SM-G930A using Tapatalk
