The issues with the motor insulation and rating tend to be more of a factor when operating the motors at the higher voltages (over 400V), and typically dual voltage motors do not have issues when run off of a VFD at the lower voltage. The stock lathe motors are single voltage, and not inverter rated, but I have yet to hear of a motor failure running it off of a VFD. TENV motors do not need any cooling fans even at the extremes of its operating range, they rely on the mass and convection to dissipate the heat as opposed to a fan. Three phase motors that are designed to operate over a wide speed range (i.e. vector motors with a constant torque ratio of 1000:1 or greater) are either TENV (no fan) or TEBC (electric fan). Motors with mechanical fans, tend to cool poorly below ~15-20Hz, and the fan can fail at high RPM. So a TEFC motor I usually recommend a 20-100 Hz range, I have a TEBC vector motor on my mill and it operates from 20-200 Hz. The TENV motors I have installed just get slightly warm, even with hard use. They are very quiet in operation.
The TENV inverter/vector motors come up on eBay new for 20-50% of current market pricing, so it is a matter of hunting and looking, you have plenty of time to snag a good deal if looking. Below are two 1.5Hp versions of the Baldor IDNM/IDVSNM, these are vector type motors so designed to be used with a VFD. They are beasts, and if you can get the first motor for $200-225 shipped, I would say that is a very good deal with he cost of shipping. I would want to see a picture of the first motor before buying it although he says it is new, then make an offer if you are interested. Given that the 1236T single phase is 1.5Hp, and also that you can substantially over drive the inverter type motors, you should have no shortage of power. There was a 2Hp version of the IDVSNM3587T that just was sold to another HM member at about 10% of current market cost.
Baldor-Reliance IDNM3584T Inverter Drive Motor, 1.5HP, 1760 rpm, 145TC
Find many great new & used options and get the best deals for Baldor IDNM3584T General Purpose Motor at the best online prices at eBay! Free shipping for many products!
www.ebay.com
Find many great new & used options and get the best deals for Baldor IDNM3584T Industrial Control System at the best online prices at eBay! Free shipping for many products!
www.ebay.com
