- Nov 26, 2017
- 1,536
I just measured the opening. The arms can open to 2.125" with no problem. (Actually can go until 2.3".) Not going to machine the arm slots. They are good enough. The limit is not the arms, but the cut out and the spring. The spring just peaks out from the bottom of the arc. No need to risk ruining the part for zero improvement. Have to use the angle blocks for something else...
That is the beauty of the tradition type of knurling tool. It is pushing from one side with the distance between the rollers fixed. You can basically knurl anything that fits in the lathe. But lining them up to get even imprint of from the rollers take a bit of effort using a rocker type tool post.
I am sure there are advantages to this configuration and I am sure that you learned a great deal, working through the build process. I think you did a great job. A lot of thought had to go into this.
