- Dec 20, 2012
- 9,422
I wouldn't really call it two methods of thought. It really depends on the material hardness one is working with & the type of knurl they are after.
For softer materials & fully formed knurls you can get away with just feeding in until the knurl is formed properly. For harder materials & partial form knurls calculating is almost always needed to avoid double tracking. For partial form knurls you could get away with just feeding in until a proper knurl is formed & then skim the peaks off to get a partial form knurl. That is if final diamter is not important. And if you are working with a cut knurler you will more than likely need to calculate rather than getting lucky.
Will, when we first try knurling I think most of us probably start off calculating diameters and expect that this will unfailingly lead to good knurls, only to find that we mistrack anyway. This leads to confusion until we figure out that it isn't just about diameter but pressure and other variables, and that isn't in any of the worksheets or calculators I have seen. Moreover, the type of knurl you use makes a difference. Diamond knurls, when used in a scissors knurler anyway, are not as diameter sensitive as straight knurls, and coarser knurls tend to mistrack less than finer knurls. Then there is the fit of the wheels on their axles that can lead to unpredictable movement. There is enough variation in the process that the calculations, while they may help, are not the only determinants of success.
If we just absolutely have to produce a knurl on size and if we can produce a full form or partial knurl properly then I agree that the calculations matter but how often do we do that? Most of the knurling done in my shop is decorative and quite often the OD to be knurled is not machined to a calculated diameter; it just is what it is. What matters to me is that I put good knurl on without wrecking my project.
This is why I suggested that Franko try both ways and see what works for him. I started out doing calculations and found that most of the time it was non-critical for most of what I do. I don't own or use a cut knurler but if I did then my tune would very likely change.
