@Dontheo55
Interesting work, please, keep us updated as you work through it. and remember photos. we love photos. Photos or it didnt happen.. LOL
What motor do you have, Brushed or brushless? have you upgraded to a more powerful motor?
Do you have a single speed or 2 speed headstock? (2 speed gives great torque in "low" even with brushless)
As to upgrades & mods, I could write a fair list
of things that can be done
but I will refrain for now other than the following....
Have you fitted brass gibs?
Have you done the "bearing" mod for the top slide feed-screw? (See YT Channel "We Can Do That Better")
Have you thought of a "bearing" mod for the cross-slide feed screw? (new feedscrew, custom carrier boss)
Have you done the "Extended travel" mod for the saddle?
Have you swapped the plastic handwheels for metal ones?
Do you have a single half nut & hook, or is it dual half nut?
Do you have an apron swarf guard (on the rear side)
Are you change-gears metal or plastic or Have you fitted an ELS to get rid of the change gears?
Are your reverse tumbler gears metal or plastic?
Do you have a large (100mm) foot tailstock that is more stable?
Have you made a new locking plate for the tailstock?
Have you made & fitted a carriage lock integral to the saddle?
OK, OK, I will shut up now! LOL
