What should I do with the set screw in this situation?
I have been rebuilding a Nantong. Large drill press and came up with a dilemma in the step pulley. Pictured below is the shaft with key.
There is a hole drilled in the pulley that lines up with the key but there are no threads in the hole.
Shown below is the pulley slipped on the shaft. My question is should I tap the hole and put in a set screw or leave it as it is. I have worked with Chinese equipment before and have seen things undone and left out. Your experiences would be helpful here.
