Correction to the pdf file. I found the test bar from a couple of years ago. I have that bar should be at 10 Degrees not 30 and the depth is .875. The 1/8 vertical seems to be ok. The 60 degree face is correct. I really need to get back and finish this and lock in dimensions. If you get yours done, please post final dimensions and angles. The test bar I made is close but not right.
