- Mar 5, 2012
- 315
My military surplus mill didn’t have a way to lower the table ( it was missing)
i had H1 (Hummer) steering wheel well used.
I adapted to the mill
Did not read the whole post now,but can you easily remove it if it is in the way?Finally had time to finish and mount a steering wheel in place of the lever style quill feed on the mill. I've been wanting to try one out, but didn't want to drop $200+ on a commercially made one, only to find out I didn't like it. So, I found a Cub Cadet steering wheel on ebay for about $25. Some CRS bar stock, a few 5mm dowel pins, and a little time. So far, I really like it. The wheel size is perfect, about 13" diameter. Will see how it feels after using it a few weeks and decide if it stays, goes, or is used occasionally. Loosen a few set screws, and it comes right off.
Thanks. Everything is pretty much from the same era. The mill is a 1978, the steering wheel is off a 77/78 Cub Cadet mower, and I'm assuming the knob is from about the same time frame, maybe earlier. Used the knob a bit yesterday, and I think it will stay put.I like that it looks like it would belong there. Nice wheel, looks vintage.
Yes, the whole assembly comes off with three set screws, and then the factory lever can pop right back on.Did not read the whole post now,but can you easily remove it if it is in the way?
