Ok...... so being the obvious “newbie” on the thread I have some questions. I looked at the original drawing. Are the holes in the 1 and 4 O’clock positions the ones that are out of alignment? I ask this becaus as a newbie I would have looked at the drawing and seen 6 holes all equally spaced and just commanded my DRO to make it so, and “voila”; which would have been wrong.....
Would somebody (if you don’t mind taking the time to do so) show me what went wrong and why. Thanks guys!
Derek.
Derek,
You are correct, the holes at the 2, 4, 8, & 10 o'clock positions (Qty. 4) are the holes which are not evenly spaced on a bolt circle relative to the 12 & 6 o'clock holes. You could easily miss this (as I did) by noting the 2.312 DIA BC callout and assuming they were evenly spaced, however the dimensions on the print do correctly show you where to place the holes if you pay attention to it.
Like you described, I set up the bolt hole circle wizard on my CNC and let her rip, not realizing the error until after the drilling was done. They are close enough to evenly spaced that you don't notice it visually super easily.
The reason this is designed this way is that there are screws that come from the outside of that flange (facing down towards my machine table in the picture) that pass through this part, through the cylinder head, and finally thread into the cylinder casting. The screws have a head on them that is wider than the thread (like every screw) so the bolt holes need to be located far enough from any features on the casting that would get in the way of the bolt head. If the holes are evenly spaced, the screws hit ribs on the casting.
As mentioned above, the drawing could have depicted these holes in a different way as to avoid the risk of confusion.
The ribs are visible in the photos below.
