This started without plans. Then I realized I better get some set up. I can't just wing it like others. I had an idea in my head to use this chunk of Aluminum, after cutting it, is when I realized that I need some idea of sizes of things.. Probably it would have been better to start that way. I needed a little more meat on the thickness to follow the plans. The plans were by Mark Frazier, he translated some SB sizes .. They seem too beefy for a SB9 in my opinion.
The pics are here on
Facing the blank
Turning it.
Begining to bore out the hole larger.
Parting it off
This was the first time I power parted. I normally always hand feed on parting. But this was going to be a lot of parting. I set up for a pretty high feed rate, and it was great. It spewed chips off as I hoped it would. I am now using power parting more.
I'm going to avoid using the pics on HM because of image size. Let's see how this works.
