Hot Damn!
First thing to do when you get your mill powered up and leveled is to stick a sharpie in the spindle. Pretend it's a tool and use it to draw parts and move the axis around. If you crash it, no big deal. Ask me how I know that a sharpie is actually two pieces and they can telescope together with enough force...
Strongly suggest a tool holding system like the TTS setup. Also, there's a couple of power drawbars available for the Novakon and I can't recommend a PDB highly enough. Night and day when you finally get to machining.
Tooling - buy carbide. Don't bother with cheap HSS end mills. Carbide is more expensive, yes, but when you crash I've found it better for the end mill to quickly snap than beat the hell out of everything before it breaks. Might even save your spindle or other parts.
Also - check out Amazon for tooling. Once in a while some vendor is tired of paying Amazon for shelf space for a single end mill. They then discount it a massive amount (like 90%) to move it. Once it's back in stock the price goes back to normal. Down side is that there's usually only one or two of whatever it is left. Up side is, if you can live with maybe not quite the exact tool you want, you can get a ferocious discount. I bought brand new Niagra a 3/4" carbide rougher for $12.00 this way.
Buy a license for a feeds and speeds program when you're ready to make chips. There are two bigger ones on the market (you can search, I won't shill) and they're superb for wrapping your brain around feeds and speeds. Helps get a feel for 'ball park.'
Measuring tools, parallels, clamps, fixture bits, coolant system, tool holders, etc. You are so up the creek.
We aren't going to hear from you for months now that you fell down this rabbit hole...
-Spumco
-Spumco
