Mobile machine shops are fairly common around water shipping ports like Baltimore Harbor near me. Overseas ships get into port and sometimes need parts they can't make onboard. They're usually custom made based on at least a F650 chassis. Typical rate is $300+ per hour while machines are running.
Ray
Not to hijack the thread but this one was Vietnam era. I did have the whole trailer, I just don't live somewhere conducive to storing a gull winged semi trailer, and my parents were tired of looking at it in their yard. The generator had about 300 hours on it. It did have the ability to be externally powered so operational hours may be higher. My guess is it never went to Vietnam or it probably would not have made it back. The lathe shows little to no wear to my untrained eye. My guess is it was for working on tanks and such, the whole trailer was outfitted for really big stuff. It had a 25, 50, & 100 ton press, Powermatic 1200 drill press, big Baldor grinder, valve grinding jigs, nice 2 stage air compressor, and some other doodads (all 3-pahse). Most anything that was not bolted down was missing though.
This is following the trailer home for 7 hours. It is the only external picture I have of the whole thing. In hindsight I should have taken more (I think there are a couple form the for sale ad, but not sure if they still exist). I sold the trailer shell with the 3-phase generator, power panel, and welder in it. It is probably retrofitted for oil country or in South America by now. You can buy one from DRMO every once in a while.
Here is the lathe in the trailer and me and my dad removing it.
Dad is very friendly.
Me with the lathe the day we moved it prior to getting the motor back on top. I am 6' tall for reference. The stand I built is too tall, but going to be a bear to shorten at this point.
As far as the stand. It is mostly 2x2x3/16 tube with 1/8" plate on top. Probably weights about 150lb. Very stable, but not in the massive cast iron weight category. I am relatively new to machining and don't do this for a living, so trying to hog of 1/4" from steel is not something I am likely to try anytime soon. I have gotten some harmonics turning long(ish) rods. I assumed a follower rest should be used, but that is the one common attachment that was not included. Sooner or later I will try and make one since finding a OEM one will be nigh impossible.
There are more pictures of it in the album that the links above are in. If anyone is interested in something in particular I will be glad to photo it. From what I can tell it is just there standard 17" lathe with factory risers, so while it is uncommon dimensionally, I don't think it has any features that are.
Edit: As far as leveling, it has adjustable feet on the stand. But, from what I can tell perfectly level is really not important as long as it is true with a test bar. If level was truly necessary the machine shops in ships would have a real difficult time operating. Although, I did level it as best I could with a Starett 98-12 level. Probably a little short, but so is the bed of the lathe =).
