Here is the latest brainstorm...
i'm attempting to design, print, and test my own 3/8" square deckel U2 collet, ala Ulma Doctor
i took the dimensions for a U2 collet and made the mock up in Tinkercad, then printed the prototype on the Ender5.
the design was close, but needed to be tweaked to fit better
a second version was on the R&D block
the deckel collet has a 20mm buttress thread
in my design, i single point threaded the collet end to 3/4"- 10tpi, as a close approximation
since the collet draw nut also has a buttress thread, i need to copy and thread a new draw nut
here are pictures of the progress until now!
due to the 30% infill on the print, the collet threads are weak and interrupted.
i think i'll need to create a sleeve to adhere to the collet, then cut threads into the sleeve to make a better threaded area
