- Feb 2, 2013
- 3,916
I have a Deckel SOE clone grinder
(https://www.hobby-machinist.com/threads/kunming-kxm10-4-universal-cutter-grinder.59697/)
i wanted to use it for sharpening HSS blanks into precision carving instruments.
this would entail putting square HSS stock into a round collet.(because i don't have any square, imperial, deckel style collets)
A) i could purchase them, or B) i could spend way too many hours fixing a problem that had already been fixed by someone else , a lot smarter than i).
of course, i chose-B
my idea was to design and test consumable 3D printed collet bushings in PLA, and utilize the bushings to sharpen HSS precisely
i designed 2 initial test collets. one for 1/4 square HSS and one for 3/8" HSS blanks
here are the results
i sharpened a 12° metal munching HSS tool in less than 10 minutes, that will shave the hairs from your arm!
The 3/8" bit collet fits into the 5/8" deckel collet
the 1/4" bit collet will fit the 1/2" deckel collet
the inspection on the 3/8 bit was good!(pictures were horrible)
i'll be doing the 1/4" bit next, then ??????
