- Jan 22, 2011
- 8,016
9mm square socket sacrificed for the project? Not sure how common those are. Might be worth a look.
So THAT is the purpose of my four jaw drill chuck!Easy, just get a square drill...
Although I sent a PM to the OP about what he ended up doing to achieve his goal, I'm going to revive this thread to [hopefully] get more thoughts on a similar problem.
You see, we have a project involving steel and wood (our specialty) that involves 1" square holes in 2" x 2" x 0.065" mild steel square tubing. I realize that using our very nice mag drill and a couple of Pferd files would get us some of the holes we desire, but we have close to (50) of these holes facing us...and it's one of those jobs where, once it's started, it has to be completed quickly.
I've watched folks online fabricating and/or using HSS press broaches to make square holes, but, considering the thickness of the tubing we have to work with, my thought is that we would deform the tubing via an arbor press or the like...and this is a rather large rack that will show every connection and/or junction.
As I alluded to before, we are wood people, so we don't own a steel lathe or a milling machine. On the other hand, we do have certain tools available to us, like the mag drill I mentioned earlier, angle grinders, high-speed die grinders, RotoZip tools, MIG welder, etc. It may also be useful to add that 1" x 1" square tubing will pass through the square holes in 2" x 2" square tubing to form a "cross" shape that, once all is set up, will be welded together.
Thank you very much for your time
If you are going all the way through, AND have a mig welder, perhaps find some square tubing that has a 1"x1" ID. Then, drill a hole big enough for that to 'slip' into the 2x2 tubing, and weld it into place.
