I am thinking about building a h frame shop press. A manual one like you see at HF. but I need to find the return springs. Anyone here know where I might find them?
If you are building your own press, have a look at this Enerpac press. The table is raised and lowered by a single lift point. They are using a cylinder, but a small worm drive winch from Harbor Freight would work just as well.
What is not easily visible in the photo are the rollers that run on the left side post. I have used a press like this and it really works better than having multiple cables and pulleys.
An improvement on this design would be to have the lower roller shaft be adjustable to level the table.
David, Not sure how I could run a cable through and still let them stretch. Could you clarify on this a little? Would the cables be just a little longer than the stroke of the ram? So if the spring failed the ram would not crash down?
