Spot welding is used to make them. Fancy bandsaws come with built-in spot welders. It requires a butt weld, though. You grind the ends square, force them together in a fixture, and run current through the joint.
You can also braze them with silver solder. I've done so successfully. In that case you grind the ends to make a lap joint.
