Hi guys,
OK - opened up the 2J head today and made some interesting observations.
1. The first thing that seemed strange was the wear on the thin plate that covers the bull gear area. There are lots of cuts in the plate caused by the lower belt. This would indicate that the lower belt was riding too low in back gear. It appears that this is due to synchronization issue with the splines on the shaft connected to the Hi-Neutral-Lo lever. It was driving the main bull gear too low. Please correct me is this assumption is false.
(edit: OK, this conclusion makes no sense. There is apparently another issue which I need to look into)
2. Next I noticed that the small bull gear was higher than the main bull gear when in backgear. See image below. As I understand it, the small bull gear should be lower than the main bull gear when in backgear. Yes, no?
3. When in backgear, there was excessive friction load on the main bull gear from below. This would seem to indicate improper synchronization between the hi-neut-low selector and the spline that it engages.
4. The small bull gear top bearing (right side in photo below) was touching the small bull gear, causing friction between the gear and the bearing. At the same time, the gear was riding substantially above the lower bearing. This was causing the small bull gear to be engaged with the large bull gear when the spindle should have been in neutral.
Based on these observations it seems my corrective actions should be :
1) re-synchronize the spline on the hi-neut-lo shaft to raise the bull gear enough so that it spins smoothly when in backgear. (I tried this by rotating the gear shift lever a bit, and there was big improvement)
2) move the small bull gear lower on its shaft so that it is not engaged when the hi-neut-lo lever in in neutral. This should also eliminate the friction between the gear and the upper bearing. Shown is the result of that move. Note the gap between the gear and the upper bearing on the right. MY BIG CONCERN is: why is the upper end of the key exposed as seen in the photo below. It appears that whoever touched this last move the gear to completely cover the key. NOT SURE EXACTLY WHERE TO POSITION THE GEAR ON THE SHAFT.
3) position the top bearing on the small bull gear shaft to properly engage the bearing cover. (no clue how to determine this)
Any and all feedback welcome.
Thanks,
Paul
