- Jul 9, 2014
- 613
No. That is for the 1/8" dia. pin that gets installed after you slide the index pin through the hole in the headstock over the spring loaded ball. It just keeps you from accidentally pulling the index pin out of the headstock (and probably losing the ball and spring). There is no groove or ring for the ball. It just holds the index pin in position by friction.
For exactly that reason of the pin not being locked in both the in & out position I turned two small grooves to locate the ball bearing to the pin to give it a better lock , as on one occasion I accidentally pushed the pin into the bull gear when I was fastening some thing to the face plate .
I didn't notice it till I tried to rotate the face plate by hand before starting the lathe up .
