- Dec 18, 2019
- 7,063
Emboldened and chastened by my recent mini-lathe spider project, I decided I would try making a spider for my 10x22 lathe. I bought a chunk of 4340 (don't ask me why, I don't know what I was thinking) that was 2.25" in diameter, which matches the OD of one of the spindle jam nuts. I cut off a piece about 1.75" long and faced it on a lathe. I used TCGT inserts on this, simply because I was too lazy to change them for TCMT. I have loads of TCGT inserts. It seems the TCGT has worked fine. This surplus 4340 has a ratty exterior, but it is dark and I'm not sure if I will turn it or not. To turn it, I'd need to make a mandrel, and I'm not sure I want to bother. I drilled it to 7/8" in two steps. After that , I will bore it.
My lathe spindle has an M39 x 1.5mm thread. On my mini-spider, I just copied the OD of the spindle thread and made a male screw for a pattern. Apparently I didn't measure it well enough and it didn't fit correctly, causing me some grief. So this time, I think I'll measure the pitch diameter and then make a male pattern to match. It's really a good idea to do this, especially with a metric thread. Even though you can detach the chuck, it's a bit of a trouble re-syncing the thread. Much better to use a male pattern test piece (if it is the correct size!). Of course I don't have a 1-2" pitch micrometer (have a 0-1") so I'll have to fiddle with thread wires - if I can find them.
The spindle bore is 26mm (measured previously), so the bore of the spider will be no smaller than that. Like the first spider, I didn't start out with a drawing, so I think my next steps will be to make a drawing, and to find some reference that gives me pitch diameter of an M39 x 1.5 metric thread. Found the pitch diameter specs at Engineer's Edge. https://www.engineersedge.com/hardware/metric-external-thread-sizes2.htm
I found my handy dandy 1 wire spreadsheet and put in the values to calculate the nominal 1 wire measurement for an M39x1.5 6g external thread. IF I got it right, I calculate out a nominal value of 39.273 mm (1.5462") over 1 wire using a 0.040" wire. The male form should be turned down to 38.968 mm max and 38.732 mm min. Yeah, so 39mm which is 1.5354" which isn't a convenient stock size for me. Well, I'll rummage around and see if I can find something. In the interim, I need to do a drawing.
In any case, I need to simply do a 1 wire measurement on the spindle thread and duplicate it for the pattern...
