Thanks, Tom. I tried to view the link on both my computers and it failed to load. Then I tried it on my phone and that worked.
Kroll, see how free machining steel cuts? It forms small chips, not strings.
Your work piece is really long. With the limited relief angle and large nose radius, the work can deflect. You will have better results if you work up close to the chuck. Try re-grinding your tool, get the work area closer to the chuck, and try taking a healthy depth of cut. I'm wondering if you have a work hardened layer that is causing the tool to skate.
