Kroll, 1144 is a free machining medium carbon steel with a machinability rating of about 82% (compared to 1212 steel at 100%). LMS lists a cutting speed for HSS at about 70-215 and 670-800 with carbide. You are supposed to calculate your RPM, pick a feed rate and see how that works. LMS's table lists a feed rate of 0.004 ipr when using their cutting speeds so you can start there.
You should know that tables like this can be misleading because they do not take into account what kind of tool you're using. There are MANY kinds of carbide tools and they do not all cut the same. In fact, every insert has their own cutting conditions. Same thing with HSS tools; not all are created equal. I don't know how powerful or rigid your lathe is but that matters, too. I raise this because if you follow the tables blindly then you are likely to run into issues and may not be able to sort out why.
There is no table that takes all of the variables into account. I can tell you what I do and maybe that will give you a place to start so that you can sort out what will work for you.
1144 is one of my favorite materials to work with. It cuts readily and finishes to a nice satin finish. It does not produce a mirror finish with a turning tool, at least not in my hands. Like most medium and high carbon steels, 1144 likes to rough slow and finish fast. I have an Emco Super 11 CD lathe. It is pretty rigid for such a small lathe and it has a 2HP motor that can run at up to 2200 rpm. I typically use HSS with 1144 because it likes sharp tools. For roughing, I use a cutting speed of 40-60 SFM and tend to feed a bit faster at about 0.006ipr. To finish, I speed it way up to 2200 rpm, slow my feed to 0.0018ipr and take very light finishing cuts. This gives me a very fine satin finish.
I also use an SCLCR tool from time to time. I use a CCMT 32.51 and rough at 100 SFM/0.006ipr and finish at my lathe's max speed and I tend to run a slower feed. Depth of cut varies with how much has to come off. Since my insert has a nose radius of 0.015", I tend to rough at about 0.020" depth of cut or more and finish at 0.010 DOC or so.
Your results WILL vary. You have to set your speed and feed someplace and look at your results, then change stuff and see what happens. Sorry but there is no magic formula, no magic table; there is what happens in your shop with your lathe and your tools. I hope you understand that we all have to go through this stuff in order to understand how our lathes cut. It's sort of fun, actually.
Give it a try and don't be afraid to mess up. Play with speeds, feeds, depths of cut, and cutting oils. Eventually, you'll find a combination of these things that works for you.
