- Jun 12, 2014
- 4,881
This may also be a reasonable option if you have a 28 mm shaft which is the standard size for a 100L motor. You can remove the variable pulley attached, motor should be good for at least 2X its base speed. There are also other metric 100L motors that in various configurations that I have also seen used with an adapter plate, but issue may be the shaft is too short.
![www.ebay.com](/proxy.php?image=https%3A%2F%2Fi.ebayimg.com%2Fimages%2Fg%2FirQAAOSwoydWlDyj%2Fs-l400.jpg&hash=42bcf4ece5dd89d7ec3af07996afed6c&return_error=1)
Spindle Motor with Pulley Assembly for Mill- MP8008 | eBay
Part #: MP8008. 230V/3 phase 3 HP Motor. Can fit Acer, Bridgeport, and most Taiwanese Variable Speed Milling Head. Speed: 1,430/1,720 RPM. Orders under 150 lbs. Orders above 150 lbs. Piscataway Office.
www.ebay.com
