Thank you so much. I did get the "screw" which turns out to be a nut, off. It came off easily. But when I try to remove the crank it only moves a little bit and stops. I hesitate to use force. I do have the parts list and it shows the pin. I think that I should try to keep the pin from dragging across the threads, correct? Here's a pic with the screw/nut removed.
