- Feb 1, 2015
- 10,121
This trick also works well for spraying insulating foam into otherwise inaccessible spots.
Not really, I used some 1/8" I.D. polyethylene tubing. If you squirt some acetone in the tube immediately after using it, the foam melts down. A small plug of acetone soaked paper toweling will push any residue out, After the foam has set up, it can be pushed out with a length of 1/16" rod. At any rate, the tubing is cheap enough and it allowed me to get into some pretty deep pockets so it would be well worth disposing of it after use.That would probably make your tubing a one-shot affair though wouldnt it? That stuff is sticky and nasty.
