Odd that "Kamakura machine tools" search brings no results, is the op sure that this is not a knock off of the well known Japaneese CNC manufacturer Nakamura?
Also have to buy a mill to use it on. Does it ever end?True, but then you have to buy and true an angle plate and contend with the lost height in Z.
Well you need to buy a property or shelter to build the shop in so theres also that requirement!Also have to buy a mill to use it on. Does it ever end?
There are inexpensive shop made versions of RTs. You don't need to buy one.
Really depends on your needs, time, application, ability to make parts to desired tolerance, and of course what is left in your wallet at the end of the month.
Daryl
MN
Evapo-rust is a reliable product, it says so... For a surprise and no chemical vs skin issues try any [but especially orange or cherry] citric hand cleaner pastes with pumice [mild abrasive, Moh's 6]. Dry oil, surface rust and usual subjects go away neatly. I won't say it's fast but quick enough. Use cheap versions of kitchen sponges, non-woven scrubbers, and toothbrushes. Also, you can belt sand or grind bristles to shorten [stiffen] them. An entire mill can be done some thing; oil, goo, coolants and sound paint remains.View attachment 235707
Well, compared to the first pic, i have to say that it is looking a tad better! I need to go to O'Reilly's tomorrow and pick up some Evapo-rust.
Yes, News merged into Yuasa, latter being the parent. There is tooling around called News-Yuasa reflecting the overlap sequence. Wonderful tooling, to be sure. Another great Japanese iron producer, unseen of late, Eron; vises, angle plates, mag-chucks, unique nesting parallels, every bit satisfactory as Yuasa, News, Lyndex-Nikken, Big-Daishowa, Showa, Tajima. Having bought personal tooling I use at jobs nearly 50 years, never regretted a dime on Japanese tools. We should be proud they allowed us mentor, and follow our lead.Definitely not a knock off. Kamakura rotary tables are known to be high quality. They could have eventually been absorbed into what is Yuasa International today. Kamakura & another Japanese rotary table manufacturer used to make rotary tables labeled NEWS. From what I understand NEWS became Yuasa. Not for sure what happened to Kamakura, just speculating.
