This isn't a "project" topic, but I didn't see any other sections that dealt with welding so I figured this was the closest. If the mods want it somewhere else feel free to move.
My question is related to welders out there that do SMAW/stick welding, both AC and both polarities of DC, that are respectable machines.
My machine is a FCAW/flux core 110v unit that is pretty light duty. I've done some significant welding with it - more than I should. I've run it on 1/4" A36 before and have not had a weld break on me so I suppose that is a good thing.
What I want to be able to do is up to 1/2" A36, with the rare exception of thicker. Multi-pass on the thicker metal isn't a problem so long as I can get adequate access to the joints for it. So the "sweet spot" for what I am after with welding is metal thickness is between 3/16" and 1/2".
I don't want to limit myself to electrodes, nor just mild steel. So having both DC polarities, also, is a must.
Another must is single phase power.
A few weeks ago I took a project over to a buddy's shop and used his AC stick machine. With 3/32" 6011 electrodes I turned the amperage down to 90 or so. We started at 150. I had 3/8" and 1/2" plate being welded to 1/4" square tube wall. The arc was just about to blow through the 1/4" so I pulled the amps back so I could get a better weld bead without blowing through the base metal. One root pass and 2 passes on top to fillet. In some areas I laid a cap pass on top to clean up the appearance some, but I don't think that was necessary for strength - the 3 other passes, ugly as they were, penetrated plenty far and had plenty of surface area to stick to.
I do not know what the welder was - but it was AC-only and run between 90-150a. On that diameter/type electrode that worked for the project - and those were the heaviest welds I've ever had to do. With larger diameter electrodes the current would likely need to go up, as to where I am not sure - so that is one wild card.
The Lincoln AC/DC 225 "tombstone" welder looks like quite a classic, and doesn't take up a whole lot of space. They look quite a bit smaller than my buddy's AC machine. However, they are fairly light duty cycle welders from what I see. Maybe that won't hurt me too much on the lower amperages?
What are your thoughts? Are there any specs that you think I should have a better idea of?
Something else I don't quite know the in's and out's of is how the welders do "DC". They obviously have to have a rectifier post-transformer. Do they filter that DC with capacitors? Inductors? Or is it all just "dirty" (unfiltered) DC pulsing above or below 0v at 60hz with the AC cycle, just all in one direction? Or does that depend on the welder?
I am not looking to get overly detailed - my goal is namely to be able to weld thicker mild steel, and for that AC will do the job. I just don't want to limit myself to it if I can get more bang for my buck in an AC/DC power supply.
Later down the road I want to be able to do TIG and MIG, but I don't want either as options on a stick power supply. I just want stick, thats all. It will be a good back-up machine if I get a better unit for MIG and TIG later.
