I'm with you brother, only $25 and days of looking for salvaged materials would be my typical cost.I would never spend $10.00 on something I can make for $25.00 and hours of labor.
If you have the capability, make it.
Dave
Essentially yes. First I roughed it undersize with a fine tooth hogger, then used this shell mill thinking (hoping?) the bottom surface might cut cleaner than a regular end mill. The side turned out ok but the bottom was a bit scratchy.did you use a regular flat bottomed mill tool to do the vee and just set the work at 45 degrees and raise the knee and take cuts?
easymik29 - I think I like yours more! I only have one small reservation & that's maybe the threaded holes coinciding. Have you made one already?
