- Nov 28, 2016
- 2,694
Is that just a small pipe tap?
Small pipes ! JK , Is the tap itself tapered or just marked a taper tap ? Maybe they are referring it as a starter tap ? 1/16th pipe tap has 27TPI , maybe a special size ?What would it be used for?
Is it a tap for use on a small bore oil line on a classic/vintage/veteran vehicle pressure gauge perhaps or something to do with A/C?
Only taper threads I have ever seen that size are nominally on pipes or fasteners for gauges or A/C...........
HOLY COW!!! Just spotted this one online! F*** me sidways that is expensive!!!!
https://www.raptorsupplies.co.uk/pd/north-american/41800
Didn't see where the above said 36TPI . I see 27 tpi in the link .
I don't believe I've ever seen one of these...
I can barely read the script on it, but the best I can tell, it says "1/16-36 taper thread"...
-Bear
