Small Lathe
Hi Ray, this was the stain. It is now drying with clear varnish.
As for the height, that rack is just a drying rack, the board is to mount the lath then it will be placed on a bench, it's mounted to the board so I can move the whole lathe around quickly when required. On the same work bench my Chinese mini will also be mounted but that will be bolted to the bench.
This lathe has a brass bed, I cleaned it up and it looks really nice. Moves really smooth now aswell.
I have now mounted the lathe, painted the speed control box. I don't have a 3 jaw chuck ( yet ). I found a large nut and there is the first go.
Nice job.
Looks like a Mighty little lathe.
Impressive!
Did your lathe come with centers for the tail stock and head stock ? You no doubt took very light cuts which requires a lot of patience. I was taught that long pieces should be supported by the tail stock to avoid damage to the machine and maintain accuracy.
Have a good day
Ray
Hi Rock, Yes it came with a talk stock as well. I did take small cuts but it's pretty surprising how it feels. It did not feel risky or like it was going to fly out or jerk to hard when I took a cut. I was in a rush to test it out. What I will do is set it backup and do my best to center the piece and then do a little video. Maybe I am patient but it didn't feel too bad/slow. Having said that I have nothing to make and am just testing it out.
I have been using this lathe a bit and I purchased a small DC motor with a worm drive reduction gearbox and machined a bush to fit ont he shaft and used one of the gears on the thread cutting attachment.
