Couple thoughts ...
(1) As far as Taig using aluminum extrusions, I'd strongly surmise that it's because a (custom) extrusion is a net or near net shape. So they can use it easily. Yes, it's "ringy" (my non-sophiosticated hillbilly engineering terminology). So they fill it with the E/G.
(2) I've filled the column of my Harbor Freight 44991 mini-mill with E/G. Just for fun, I decided to add some "long distance" stiffness by including 1" drywall screws and some ~½" 4-40 screws in the mixture (along with glass beads and aquarium gravel). Didn't do any sophisticated testing of the final result, but it does seem to have helped with rigidity and vibration damping. I used West Systems epoxy with the slow hardener, in hopes that the long cure time would allow air bubbles to escape. When mixing it , I stirred slowly, trying to reduce introduction of bubbles. Once poured, I used a vibratory engraver (with an extension) to agitate the mix. A bunch of bubbles did float to the surface before the epoxy cured. And I was pleasantly surprised by how well the epoxy wetted out the filler materials.
