- Dec 17, 2012
- 630
Ok, starting out now that I am getting other stuff out of the way. To begin with, I am starting with the spindle. I began with a 100mm long 8mm shaft ER11 collet holder that I got off Ebay for $16 with free shipping. It has been lost here in the house for since August and I finally came across it last night.
I tossed four 608 skate bearings in the oven on warm and the spindle in the freezer. I pushed 3 of them on the collet holder shaft and bottomed it out near the collet end.
Then I took about 4 inches of schedule 80 3/4-in 6061 pipe and bored it out to 22 mm deep enough for the three bearings on one end and deep enough for one bearing on the other. Did a little clean up on the outside diameter.
Did a very light press to get the bearings into the tube. Finally, I grabbed the last bearing from the oven and slid it down into the seat on the other end of the spindle.
Next I need to make a locking collar and a pulley. Then I can decide about the power and mounting bracket.
I am still deciding on how to power it. The first options are one of two RC motors, both about 350watt with ESC. One is brushed, the other is brushless. The next option is to just put a pulley on a cheap HF trim router and run off of 120V. The final option is a sewing machine motor. Still deciding.
