I toyed with the idea of a pneumatic over hydraulic foot pump but decided that would be overkill for my needs. I found a good deal on a new Enerpac P-202 manual pump on ebay (https://www.ebay.com/itm/283805583625) and also purchased an Enerpac hose with pressure gauge from the same seller. The P-202 gives 0.221 in^3 / stroke in low pressure mode and 0.055 in^3 in high pressure mode.Thats exeactly what I want next a forging press. What is the speed you'll have with this set up?
The ram is a Jackco Model 684 (8" stroke, 10 ton, SPRING RETURN). The fluid capacity is 18 in^3. I found this also on ebay (https://www.ebay.com/itm/371383947709). Jackco publishes detailed specifications on their rams (most others don't). This one has a fluid capacity of 19.7 in^3, an effective ram area of 2.462 in^2 and a max operating pressure of 8950 psi. The effective ram area times the hydraulic fluid pressure gives the force that the ram is applying. I need to convert pressure to ram force for load testing.I have a similar frame with no hydraulics, where did you get the ram?
8” is window height, width or depth? Sorry if I’m being dense on the nomenclature
Yep, no short cuts allowed there.Enerpac makes 2 speed pumps that are not much more expensive. I wish I had gone that route. You may already know this but most hydraulic fittings are not rated to go up to 10K PSI.
Robert
Looks good. And not a weld to be found. Did you make plans for this? Can they be posted?
