And if the arbor has a key, remove it. Also make sure the direction you are turning it will loosen the screw holding it together, not tighten it up if it should get in a bind. A brand new, sharp saw will tend to sing a little if you're running it fast, so take it slow until it breaks in, just like a bandsaw blade. Run a little drag on the moving axis, even if you are up-milling.
