Well I just took the cross feed lever assembly off and messed with the push rod under it. The rod just pushed in and out with a heavy spring. I turned it and no change. Put the lever assembly back on, and again confirmed that the lever only appears to operate the cross feed. Just makes no sense to me.
Bear, the lever will not move out and to the right. Looking at the Select "Part List Of Precision Bench Lathe". There is no indication of any key that would go into the leadscrew. Here is a photo of the page.
Edit: Just added a photo of the parts list also. Hopefully the photos will shed some insight.
