I need a saw that will cut thru 4140 occasionally .190" thick but usually .040" thick.
I've been using 40mm x 1mm x 72t but the teeth dull quickly.
Would a thinner blade wear less? How about less teeth? I don't need a fine finish. I've used angle grinder cutoff wheels but they tend to not cut straight as they are too thin and flexible.
Here's some I am looking at:
US $3.15 28% OFF|Useful 80mm Outer Diameter Thickness 1.2mm HSS 72T Slitting Saw Cutting Edge Tool Y1K9 For Home And Production Saw Tool-in Saw Blades from Tools on Aliexpress.com | Alibaba Group
Smarter Shopping, Better Living! Aliexpress.com
tinyurl.com
US $4.18 25% OFF|30T Circular Metal Slitting Saw Blade Cutter 105mm x 20mm|Saw Blades| - AliExpress
tinyurl.com
