- Feb 13, 2017
- 2,138
Like any machine tool, one learns real quick to keep body parts away from cutting tools. Even when they aren't running. Think of machine screw slotted heads for a conceptual grasp. I got into slitting saws making slots in an alum plate. Soft solder won't stick to alumimium. . . Such a mandrel would allow many different bore sizes on a vertical mill. A nicely done tool like that is a staple for most any shop. Good work, Sir.I look at these things and yikes they scare me. A supper sharp unguarded saw blade spinning at who knows what rpm. I haven't figured out what I would ever do with one.
The end product I needed was a jig for making a modeling part consistantly. There are several parallel slots about 0.030" square in a piece of alum about 3 inches long. Milling wouldn't work, I couldn't find a milling cutter that small. Tried the shaper, it worked but I wasn't able to make a tool that would last. Acquiring the horizontal mill with slitting saws was a drop in solution. Along with a rotary table. . .
A common application would be making a movable clamping system. Think drill press table clamping. I have made many parts using the "field" expediant of a hacksaw to slot a clamp. Not very pretty, but it got the machines running. To make the machine in a shop, clean, sharp work is expected. A hacksaw kerf won't cut it with the inspector.
