- Apr 14, 2014
- 3,511
In his first post on the subject the OP mentioned "leather belt problems". My Seneca Falls machine also uses la leather belt, and like many other members I have tried various belt dressings over the years. The original dressing I used came in a tube and was thick and sticky. Unfortunately almost all the labeling was gone so I was unable to order more when I ran out.
After trying everything from soup to nuts I settled on 3M Super 77 Multipurpose spray adhesive. I've been using it (sparingly) for over 10 years on my 1 1/4" leather belt. It does a great job and doesn't seem to affect the belt. I probably use it 3 or 4 times a year. Having said that I don't over tighten the belt to the point the machine will be damaged in a crash. I generally tighten it to the point that I can take a .125" deep cut off 6061 aluminum. This seems to be tight enough that I can take .060 - .080 cuts on 1018 without slipping, but in the event of a crash the belt will still slip.
If the belting is worn or cracked to the point it needs replacement they can be purchased by the foot from McMaster. They also sell several different styles of belt clips and lacings.
