- Feb 2, 2013
- 3,955
Hey Guys and Gals,
i bought what i thought may be a cool little bandsaw,
a Skill 3386...
59-1/2" blades
120 VAC, 2.5 amps
it worked just fine on pine up to 3/8" and it did great on the 5mm plywood.
but it didn't like hardwoods nor did it like any thickness over 3/4" in just about any material.
i'm not a woodworker,
but if i wanna cut a small piece of 2x4, i feel a small saw should do it without too much effort.
this saw had a hard time doing a 2x4, a couple times- stopping the blade all together.
the blade popped off at the same time.
i adjusted the blade for best travel and tried again with a coarser pitched blade
it cut a bit better but it really strained to move the cellulose.
Act 1:
so, i figured before i returned the saw,
i'd modify it permanently to prevent that possibility
i let the issue go for a month or so,
and then got the inclination to retrofit a 48 frame 5.5amp 1/3 hpp 115v motor into the saw....
OH my friends, the plan was immaculate i tell you !!!!!!
i'd pop in a new motor , wire it up and badda bing, cut wood like a beaver on steroids.
Well, it didn't exactly work like that....
Here was the plan...
i'd remove the 2.5 amp 120 VAC (HA_HA_HA) motor and replace it with a (cheap) 1/3 hp motor drawing 5.5 amps @ 115 VAC.
i figured it would do much better than the anemic 2. 5 amp motor
2.5 amp motor, top 5.5 amp motor bottom
i wuzgunna' just take the motor mount and modify it to suit the 48 frame motor i intended to use.
well, i intended to use the extended length mount bolts from the 48 frame motor to mount the retrofit motor-
that wasn't gonna work, this time- the bolt circle ended up to be too close to the edge of the stock mount.
i considered making a larger mount plate.
i traced a pattern onto the old looking new steel and was gonna start cutting,
then i had another idea, use a wire ring mount.
we use these in our industry to mount 48 frame fans
this looked like it was going to be a slam dunk.....
but then reality set in.
i was going to need to make a pulley or make the spacer for the pulley to work with a .500" shaft i had.
here is the OEM pulley
i didn't want to go through all the trouble of making a simple spacer,
so i made another pulley from 6061
a Skill 3386...
59-1/2" blades
120 VAC, 2.5 amps
Act 1:
