Thought I would bring you guys up to date.
I usaully count my good days a opposed to the bad ones, normally I am sick more often than not. But enough with the sob story. Tonight was a good one. The first I felt like going to the shop, since first post.
I made a extended dead center, had a small enough shank that I had room to back up to start my cut.
I used another HSS that I had success with before, basically just a narrower profile but still at 60 degrees
Checked and rechecked tool height
Used thread cutting oil every pass
Checked gibs, about as smooth as it gets, nice firm twist to get things moving. So thought I would give it a go.
Made about three passes, and missed again, everything following skim up that point. So here is my process, turn in cross slide to touch.
Zero both compound and cross slide, turn compound in 3 thou (I not sure what the math says at 29 deg) catch any number, (i have been using only the odd numbers)
lock in half-nuts
run to my out, just prior to shoulder.
Release half nuts
Back out cross slide 50 thou
Crank carriage back withthe wheel. (is this where I am messing things up?)
Cross slide back in 50 thou
Repeat the above steps
