Single Point Threading Issue - might be gearing?
On my lathe the dial is held on with a screw in the middle. You might need to space the housing a bit farther from th saddle.
Ok. Now have 32 TPI. But kind of sad looking threads. There's a lot of swarf and bent over thread edges. I seem to be having trouble always hitting the mark, sometimes it drops in, and sometimes it hangs and drops in the next "detent". Would this lack of consistency of hitting the mark make the threads ratty? Is there some better way to practice? (It's clear I need to work on this.) What material is cheap and gives one a similar enough experience as single threading metal? From reading on HMF I think someone mentioned PVC pipe. That would help for the coarse threads.
Mine pivots on the screw into the side of the apron. The screw is parallel to the ways. I can adjust the depth of the engagement of the dial gear to the lead screw by rotating the dial face toward me, or more vertical. As far as I can tell that's the only adjustment I have. That's what I played with.
Hmm, forgot the picture of the awful threads.
How do you make nicer threads?
Just ran this on the calculator (https://www.cgtk.co.uk/metalwork/calculators/changegears/minilathe) Many combinations will work :
Gear AGear BGear CGear DActual TPI
20ANY4032
30ANY6032
40ANY8032
2020408032
2030608032
2040808032
2080603032
2080804032
2135506032
2160503532
3040406032
3045608032
3060404032
3060808032
3080604532
3080806032
4020208032
4040306032
4060304032
5035216032
6030208032
6045308032
8040208032
8060308032
8080306032
Roy
When I started, this morning, I had no idea that one could do ABD, and you needed to move the spacer as well as the pivots. Now, I know. :) There sure are a lot of combinations to get 32 TPI!
Sad to say, if I had actually looked at the sticker on the side of the gearbox cover, I would have seen a simplified table, and both the ABCD and ABD diagrams. :chagrin: I had turned over the cover, and never noticed it.
You can learn on PVC for higher pitch threads. Don't know that I ever did more than 24, but it worked well. Aluminum and 12L14 work well as well.
I have some 1215 (no lead) but it's hex. I can turn it down and try some. It's supposed to be free machining, but not quite as good as 12L14. I'm shying away from 12L14, etc. just due to the lead. Not sure how to legitimately dispose of the chips. Probably will also buy a stick of 1/2" pvc pipe, that should be cheap enough. ($2 for 10 feet, quantity 1)
