- Nov 17, 2017
- 1,525
This is not correct. You lose horsepower with a static phase converter, not a VFD and not with a rotary phase converter.
Err, no::
A single phase motor has 3 windings (just like a 3-phase motor) and operates like a 3-phase motor but with the phases running 0 degrees, 180 degrees and 90 degrees and the voltage at 90 degrees is only 71% that of the other two. In this orientation, the motor produces 86% of the input power as output power, whereas the 3-phase motor with 0 degrees, 120 degrees, and 240 degrees, runs at 100% input=output power. {Both neglection thermodynamic losses,...}
It is possible to make a static power converter that happens to develop 0 degrees, 120 degrees, and 240 degrees, but only if you use the motor at constant HP. This typically requires a box full of big capacitors an a few inductors.
